Use the referenced scene name | inPathReferenced – When enabled and calculating the path for a referenced container, the original referenced scene name is used instead of this scene name, this option allows Simulators from referenced scenes which use $(...) macros in their cache paths to find their cache files. The $(dir) macro will be resolved to the directory where the referenced scene resides, the $(scene) macro will have the name of the referenced scene, and the $(nodename) macro will be stripped of any Maya namespace prefixes. All other macros that include these three will also be resolved using these updated values. If a referenced Simulator uses a full path to its cache files, this option will not make any difference.
Cached Frames – Shows information about the cached frame range.
