UI Path: ||Render Setup window|| > Render Elements tab...
||Render Setup window||> Render Elements tab > Addbutton >VRScansPMask Element
width
20%30%
width
60%40%
width
20%30%
width
60%
VrayVFB– When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Color mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Setup window to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
