The VRaySoftbox is a procedural texture that can be used in a V-Ray Area Light to create the illumination coming from a Soft Box light source. The example shown here uses a VRaySoftBox texture on a V-Ray light.
width10%50%
width40%5%
Image Removed
width45%40%
Image Added
Image Modified
width10%
UI Expand
titleUI Path: ||Material Editor window|| > Material/Map Browser > Maps...
||Material Editor window|| > Material/Map Browser > Maps > V-Ray > VRaySoftbox
width40%
width20%
width40%
width60%
Base Color – Controls the color of the texture. Enabling the checkbox on the right, enables the use of maps.
Tint Color – When enabled, the color in the Base Color parameter is multiplied by the Tint Color parameter.
Strength – A multiplier that controls how strong the effect of the Tint Color parameter is.
Processing
Multiplier – A multiplier for the overal VRaySoftBox texture. It acts similar to changing the multiplier of the VRayLight that uses this texture instead.
Gamma – A gamma correction that is going to be applied to the texture.
width5%
width35%
