width45%50%
 The V-Ray Toon Render Element renders the entire scene with the  V-Ray Toon rendering effect and contains a mask for the toon outlines, although the toon color is not present in it. It also supports opacity set from the toon effect, presenting it as grayed outlines.
width5%
width50%45%
Image Modified
UI Path
width5%
width45%
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > V-Ray Toon Channel
width45%
||mat Network|| > V-Ray > Render Channel > V-Ray Toon Channel
width5%
width
50%
Deep Output – Specifies whether to include this render channel in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping
 tab of
the V-Ray Renderer
 to this render element.
Consider for AA – When enabled, antialiasing will be considered where possible.
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler
 panel of
the Sampler tab
 of the V-Ray Renderer node.
Denoise – Enables the render element's denoising, provided the Denoiser render element is added.
Invert Color – Flips the black and white colors.
width5%
width45%
Image Added
Common Uses
width20%
width60%
Image slider
Panel
borderStylenone
Image Modified
Panel
borderStylenone
Image Modified
V-Ray Toon Render Element with Invert color enabled
Panel
borderStylenone
Image Modified
V-Ray Toon Render Element with Show Toon Lines in Reflections enabled on the V-Ray Toon node
width20%
