changes.mady.by.user Gergana Lilkova
Saved on Jul 17, 2019
Saved on Dec 17, 2019
||mat Network|| > V-Ray> Utility Texture: Utility > V-Ray Invert
The V-Ray TexInvert node provides inputs that correspond to the parameters in the section below.
Image Modified
Texture
– Specifies the texture that has its colors inverted.
Invert Alpha
– When enabled, the texture alpha is inverted as well.
Image Added
