width33%
||mat Network|| > V-Ray> Texture: ProceduralTexture > V-Ray Celluar
width33%
 ||out Network|| > V-Ray Render Elements node > V-Ray > Texture: ProceduralTexture > V-Ray Cellular
width33%
Node
width50%
The V-Ray TexCellular node provides inputs for controlling various texture properties. They correspond to parameters in the section below.
width5%
width45%
Image Modified
width
50%
Type
 – Specifies which type to use for the Cellular texture. The choices
are Dots, Chips, Cells, Chess Cells,
or Plasma.
Background
Color – Controls the color of the background of the Cellular procedural texture.
Center Color – Controls the color of the center of the cells.
Edge Color – Controls the color of the edges of the cells in the Cellular procedural texture.
 – Controls the size of the Cellular procedural texture. For more details, please see
the Size examples below.
Spread
 – Controls the spread of the procedural Cellular texture. For more details, please see
the Spread examples below.
Density
 – Controls the Density of the Cellular texture. For more details, please see
the Density examples below.
Low – Controls the low threshold (background color). For more details, please see
the Low examples below.
Middle – Controls the middle threshold (edge color). For more details, please see
the Middle examples below.
High – Controls the high threshold (center color). For more details, please see
the High examples below.
Fractal – Enables the addition of fractal generation. Only available with Dots and Chips Types.
Fractal Iterations – Controls the number of fractal iterations. For more details, please see the
 Fractal Iterations
 examples below.
Fractal Roughness – Controls the roughness of the fractal. A value of 0.0 is very rough and a value of 1.0 is very smooth, which negates the fractal. For more details, please see
the Fractal Roughness
 examples below.
width5%
width45%
Image Added
Color Tweaks
Image Removed
width50%
Default Color – Specifies the color when there are no valid UVW coordinates.
Mult – Specifies a strength multiplier for the texture color.
Offset – Color corrects the texture by adding the the RGB color values specified here to the RGB color values in the texture.
Invert
 – When enabled, inverts the resulting texture color.
width5%
width45%
Image Added
Alpha Tweaks
Image Removed
width50%
Source – Specifies where the alpha channel is drawn from.
Alpha – Alpha channel is drawn from the texture.
Color
– Alpha is generated from pixel intensity.
Opaque – Alpha channel is fully opaque.
Use – Differentiate between textures exported from different applications. You can choose between Color Intensity (3ds Max) and Color Luminance (Maya).
Mult
 – Specifies a multiplier for the texture alpha.
Offset
 – Specifies an additional offset for the texture alpha.
Invert
 – When enabled
and Invert
 from Color
Tweaks is also enabled, the resulting texture alpha is inverted as well.
width5%
width45%
Image Added
Placement
width50%
Placement Type
 – Specifies the way the valid portion of the texture is applied.
Full – Uses the full valid portion of the texture.
Crop – Allows the user to specify a section of the texture using the parameters below.
Place – Allows the user to specify a section of the texture and how to place it using the parameters below.
U
 – Specifies the U coordinate of the valid texture sector.
V
 – Specifies the V coordinate of the valid texture sector.
W
 – Specifies the width of the valid texture sector.
H
 – Specifies the height of the valid texture sector.
Jitter
 – Controls the amount of random placement variation.
Tile U
 – Enables horizontal tiling.
Tile V
 – Enables vertical tiling.
width5%
width45%
Image Added
UV Noise
Image Removed
width50%
Enabled – Enables noise for the texture.
Amount
 – Specifies the amount of noise to add to the texture.
Levels
 – Specifies the amount of noise iterations.
 – Controls the scale of the noise.
Animated
 – Enables the noise to be animated.
Phase
 – Controls the noise phase.
width5%
width45%
Image Added
Anchor
exampleCellularSize
exampleCellularSize
Example: Size
width20%
width60%
Image slider
Panel
borderStylenone
Image Modified
Dots Size:  0.05
Panel
borderStylenone
Image Modified
 Dots Size: 0.1
Panel
borderStylenone
Image Modified
Dots Size: 0.2
Panel
borderStylenone
Image Modified
 Chips Size: 0.2
Panel
borderStylenone
Image Modified
Chips Size: 0.35
Panel
borderStylenone
Image Modified
 Chips Size: 0.5
Panel
borderStylenone
Image Modified
Cells Size: 0.1
Panel
borderStylenone
Image Modified
Cells Size: 0.2
Panel
borderStylenone
Image Modified
Cells Size: 0.5
Panel
borderStylenone
Image Modified
Chess Cells Size: 0.1
Panel
borderStylenone
Image Modified
Chess Cells Size: 0.2
Panel
borderStylenone
Image Modified
Chess Cells Size: 0.5
Panel
borderStylenone
 Plasma Size: 0.05
Panel
borderStylenone
Plasma Size: 0.07
Panel
borderStylenone
Plasma Size: 0.2
Move the slider to see the example renders.
width20%
Anchor
exampleSpread
exampleSpread
Anchor
exampleDensity
exampleDensity
width20%5%
60%
width45%
Example: Spread
Image slider
Panel
borderStylenone
Image Modified
Dots Spread: 0.5
Panel
borderStylenone
Image Modified
Dots Spread: 1.0
Panel
borderStylenone
Image Modified
 Dots Spread: 1.5
Panel
borderStylenone
Image Modified
Chips Spread: 0.5
Panel
borderStylenone
Image Modified
Chips Spread: 1.0
Panel
borderStylenone
Image Modified
 Chips Spread: 2.0
Panel
borderStylenone
Image Modified
 Cells Spread: 0.1
Panel
borderStylenone
Image Modified
 Cells Spread: 0.5
Panel
borderStylenone
Image Modified
 Cells Spread: 1.0
Panel
borderStylenone
Image Modified
Chess Cells Spread: 0.1
Panel
borderStylenone
Image Modified
Chess Cells Spread: 0.5
Panel
borderStylenone
Image Modified
 Chess Cells Spread: 0.9
Panel
borderStylenone
Image Modified
 Plasma Spread: 1.0
Panel
borderStylenone
Image Modified
Plasma Spread: 3.0
Panel
borderStylenone
Image Modified
Plasma Spread: 5.0
width20%
45%
Example: Density
section
60%
width20%
width
Image slider
Panel
borderStylenone
Image Modified
Dots Density: 0.1
Panel
borderStylenone
Image Modified
 Dots Density: 0.25
Panel
borderStylenone
Image Modified
Dots Density: 1.0
Panel
borderStylenone
Image Modified
Chips Density:  0.25
Panel
borderStylenone
Image Modified
Chips Density: 0.7
Panel
borderStylenone
Image Modified
Chips Density: 1.5
Panel
borderStylenone
Image Modified
Cells Density: 0.15
Panel
borderStylenone
Image Modified
Cells Density: 0.25
Panel
borderStylenone
Image Modified
 Cells Density: 0.5
Panel
borderStylenone
Image Modified
Chess Cells Density: 0.15
Panel
borderStylenone
Image Modified
 Chess Cells Density: 0.25
Panel
borderStylenone
Image Modified
Chess Cells Density: 0.5
Panel
borderStylenone
Image Modified
Plasma Density: 0.5
Panel
borderStylenone
Image Modified
 Plasma Density: 1.0
Panel
borderStylenone
Image Modified
Plasma Density: 2.0
width5%20%
Anchor
exampleLow
exampleLow
width5%
width45%
The Dots examples below use Size: 0.25, Spread: 0.5, and Density: 1.5. The Edge Color is blue for visual clarity.
Image slider
Panel
borderStylenone
Dots Low: 0.0
Panel
borderStylenone
Dots Low: 0.5
Panel
borderStylenone
Dots Low: 1.0
width45%
The Chips examples below use Size: 1.0, Spread: 0.75, and Density: 3.0. The Edge Color is blue for visual clarity.
Image slider
Panel
borderStylenone
Chips Low: 0.0
Panel
borderStylenone
Chips Low: 0.5
Panel
borderStylenone
Chips Low: 0.9
width5%
Anchor
exampleMiddle
exampleMiddle
Example: Middle
width5%
width45%
Image slider
Panel
borderStylenone
Dots Middle: 0.0
Panel
borderStylenone
Dots Middle: 0.5
Panel
borderStylenone
Dots Middle: 1.0
width45%
Image slider
Panel
borderStylenone
Chips Middle: 0.0
Panel
borderStylenone
Chips Middle: 0.5
Panel
borderStylenone
Chips Middle: 1.0
width5%
Anchor
exampleHigh
exampleHigh
Example: High
sectionsection
width5%
width45%
column30%column30%column30%
Image slider
Panel
width5%
borderStylenone
width
Image Modified
Dots High: 0.0
Panel
borderStyle
width
none
Image Modified
Dots High: 0.75
Panel
borderStyle
width
none
Image Modified
Dots High: 1.0
width5%45%
Image slider
Panel
width5%
borderStylenone
width
Image Modified
Chips High: 0.0
Panel
borderStyle
width
none
Image Modified
Chips High: 0.75
Panel
borderStyle
width
none
Image Modified
Chips High: 1.0
width5%
Anchor
exampleFractalIterations
Example: Fractal Iterations
sectionsection
width5%
width45%
column30%column30%columnwidth30%
Image slider
Panel
width5%
borderStylenone
width
Image Modified
Fractal not enabled
Panel
borderStyle
width
none
Image Modified
 Fractal Iterations: 1.75
Panel
borderStyle
none
Image Modified
 Fractal Iterations: 3.0
width5%
45%
Image slider
Panel
width5%
borderStylenone
width
Image Modified
Fractal not enabled
Panel
borderStyle
width
none
Image Modified
Panel
borderStyle
width
none
Image Modified
width5%
Anchor
exampleFractalRoughness
Example: Fractal Roughness
sectionsection
width5%
width45%
The Dots examples below use Size: 0.25, Spread: 0.5, Density: 1.5, and Fractal Iterations: 3.0.
columncolumn30%column30%
Image slider
width30%
Panel
width5%
borderStylenone
Image Modified
Fractal Roughness: 0.0
Panel
borderStyle
width
none
Image Modified
Fractal Roughness: 0.5
Panel
borderStyle
width
none
Image Modified
 Fractal Roughness: 0.9
width5%
45%
The Chips examples below use Size: 1.0, Spread: 0.75, Density: 3.0, and Fractal Iterations: 3.0.
Image slider
Panel
width5%
borderStylenone
width
Image Modified
Panel
borderStyle
width
none
Image Modified
Panel
borderStyle
width
none
Image Modified
width5%
