||Material Editor window|| > Material/Map Browser > Materials > V-Ray > VRayOverrideMtl
width
60%
Base material – Specifies the material V-Ray will use while rendering the object.
GI – Specifies the material V-Ray will use while calculating the GI solution.
Reflect mtl – This is the material V-Ray will use to render the object with, when the object is seen in reflections. For more information,
see Using the Reflect material example
 below.
Refract mtl – This is the material V-Ray will use to render the object with, when the object is seen in refractions. For more information,
see Using the Refract material example
 below.
Shadow mtl – This is the material that will be used to render shadows cast from the object.
width5%
width35%
Image Added
Example: Using the GI material
