This page contains information about the V-Ray Invert Texture node.
width45%
 The V-Ray TexInvert node is a utility used to invert texture colors.
width5%
width50%
UI Paths
width33%
||mat Network|| > V-Ray> Texture: Utility > V-Ray Invert
width33%
||out Network|| > V-Ray Render Elements node > V-Ray > Texture: Utility > V-Ray Invert
width33%
Node
width50%
The V-Ray TexInvert node provides inputs that correspond to the parameters in the section below.
width5%
width45%
width50%
Texture – Specifies the texture that has its colors inverted.
Invert Alpha – When enabled, the texture alpha is inverted as well.
width5%
width45%
