This page gives information on the Render ID Render Element.
Section | |||||||||||||||
UI Expand | |||||||||||||||||
||Render Setup window|| > Render Elements tab > Add button > VRayRenderID
Common uses
The VRayRenderID Render Element is useful for isolating geometry in a scene. This means that items can be isolated by use of a matte created from the solid colors within the VRayRenderID pass. Exact RGB values for any object in the scene can be looked up if the XML report is saved.
