The menu consists of ten different submenu's: Show-V-Ray VFB, Render in Chaos Cloud, Lights, Geometry, Tools, Global Effects, V-Ray Bake Options, V-Ray Volume Grid, Help and About V-Ray.
V-Ray Menu
 Image Removed
width
62%
MenuDescription
Show V-Ray VFBOpens the V-Ray Frame Buffer.
Render in Chaos CloudOpens the Submit to Chaos Cloud window, where you can submit your job and render it in Chaos Cloud.
LightsOpens the V-Ray Lights submenu.
GeometryOpens the V-Ray Geometry submenu.
ToolsOpens the V-Ray Tools submenu.
Global EffectsOpens the V-Ray Global Effects submenu.
V-Ray Bake Options
Opens the V-Ray Bake Options submenu where you can:
- Assign single V-Ray bake options to selection
- Assign multiple V-Ray bake options to selection
- Remove V-Ray bake options from selection
- Remove V-Ray bake options from selection and sub-hierarchy
- Force create VRayBakeOptions properties node
- Show default V-Ray bake options
- Bake with V-Ray...
V-Ray Volume GridCreates a VRayVolumeGrid node.
HelpOpens the Help submenu.
About V-RayShows you information about the installed version.
width5%
width33%
Image Added
Anchor
lights
lights
width
62%
MenuDescription
V-Ray Rect LightCreates a VRayLightRect, also known as Area Light.
V-Ray Dome LightCreates a VRayLightDome.
V-Ray SunCreates a VRaySun.
V-Ray SkyCreates a VRaySky.
V-Ray Sphere LightCreates a VRayLightSphere.
V-Ray Mesh Light
Opens a VRayLightMesh submenu where you can:
- Turn selection into lights (works for meshes only)
- Turn selection into lights (apply single VRayLightMesh)
- Remove light modifiers from selection
- Remove light modifier from selection and sub-hierarchy
- Force create VRayLightMesh properties node.
V-Ray IES LightCreates a VRayIES.
width5%
width33%
Image Added
Anchor
geom
geom
 Image Removed
width
62%
MenuDescription
Create V-Ray ProxyCreates a V-Ray Proxy object.
Import V-Ray ProxyImports a V-Ray Proxy object into the scene.
V-Ray Object Properties
Opens the VRayObjectProperties submenu where you can:
- Apply multiple object properties nodes to selection
- Apply single object properties nodes to selection
- Remove object properties from selection
- Remove object properties from selection and sub-hierarchy
- Force create object properties node
V-Ray SceneOpens the V-Ray Scene Manager.
V-Ray Fur
Opens the VRayFur submenu where you can:
- Add VRayFur to selection (works for meshes only)
- Remove VRayFur from selection
- Remove VRayFur from selection and sub-hierarchy
- Force create VRayFur properties node.
V-Ray Displacement
Opens the VRayDisplacement submenu where you can:
- Apply multiple VRayDisplacement to selection
- Apply single VRayDisplacement node to selection
- Remove VRayDisplacement from selection
- Remove VRayDisplacement from selection and sub-hierarchy
- Force create VRayDisplacement node
V-Ray PlaneCreates a procedural infinite-plane primitive for V-Ray.
V-Ray Metalball Creates a VRayMetalball.
V-Ray NURBS Tessellation
Opens the VRayNURBSTessellation submenu where you can:
- Apply multiple VRayNURBSTessellation to selection
- Apply single VRayNURBSTessellation to selection
- Remove VRayNURBSTessellation from selection.
- Remove VRayNURBSTessellation from selection and sub-hierarchy
- Force create VRayNURBSTessellation properties node
V-Ray Renderable Curves
Opens the VRayRenderableCurves submenu where you can:
- Apply multiple VRayRenderableCurve to selection
- Apply single VRayRenderableCurve node to selection
- Remove VRayRenderableCurve from selection.
- Remove VRayRenderableCurve from selection and sub-hierarchy
- Force create VRayRenderableCurve properties node
V-Ray Clipper Creates a VRayClipper.
width5%
width33%
Image Added
Anchor
tools
tools
V-Ray Tools submenu
 Image Removed
width
62%
MenuDescription
V-Ray Light ListerOpens the V-Ray Light Lister window.
V-Ray Light MeterCreates a VRayLightMeter node.
Create from V-Ray plugin
Opens the V-Ray plugin submenu where you can create:
- Texture
- Light
- Volume shader
- BRDF material
- Material
Import V-Ray material from fileOpens the V-Ray Material Importer dialog.
V-Ray StereoRig from camerasCreates a V-Ray Stereo Rig.
V-Ray VRmat ConverterOpens the VRmat Converter.
Archive V-Ray SceneOpens the Archive V-Ray Scene window where you can export a .vrscene package archive with all asset files.
Convert Materials from V-RayOpens the Convert Materials window where you can convert a material to a VRayMtl.
width5%
width33%
Image Added
Anchor
GE
GE
 Image Removed
width
62%
MenuDescription
V-Ray ToonCreates a VRayToon node that produces cartoon-style outlines on objects in the scene.
V-Ray Sphere FadeCreates a VRaySphereFadeVolume that renders just small parts of the scene by putting them in a special spherical locator.
width5%
width33%
Image Added
Anchor
help
help
Help submenu
width
62%
MenuDescription
TutorialsOpens the Tutorials page of the V-Ray for Maya online documentation.
DocumentationOpens the V-Ray for Maya online documentation.
width5%
width33%
Image Added
