Select the material in the Hypershade that a Multi Matte ID Render Element is needed for.Add
width62%
width5%
width33%
width62%
 Add the Material ID
attribute Attributes > VRay > Material ID.
width5%
width33%
Image Modified
width62%
 Set
the Multi Matte ID to the required value. Note: each number corresponds to a different color.
width5%
width33%
Image Modified
width62%
 Open Render Settings and go to the Render Elements tab and from the Available render elements add a Multi Matte ID render element.
width5%
width33%
Image Added
Image Removed
Common Uses
A typical usage of this render element, is to use the colors produced in the Multi Matte ID to produce a mask or alpha channel in post production that covers everything with that Multi Matte ID.
