This page gives an overview of the Raw Reflection Filter Render Element and explains how it is used.
Floatingpagetoc
width50%62%
The Raw Reflection Filter Render Element is similar to the Reflection Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection.
width5%
width45%33%
Image Modified
UI Path
||Render Settings window|| > Render Elements tab > Raw Reflection Filter
width
62%
Enabled
 – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix
 – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawReflectionFilter.vrimg).
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
UI Text Box
This render element is not supported with V-Ray GPU rendering.
width5%
width33%
Image Added
Usage Notes
Fancy Bullets
typecircle
  • The Raw Reflection Filter Render Element is useful when a precise mask is needed for reflective objects. Unlike the Reflection Filter Render Element, there is no need to clip or readjust values when pure black or white is required for the composite.
