changes.mady.by.user Unknown User (zheni.metodieva)
Saved on May 13, 2020
Enabled – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawReflectionFilter.vrimg).
This render element is not supported with V-Ray GPU rendering.
