This page provides information on the Render ID Render Element which renders individual objects with different colors based on their internally assigned IDs.
Floatingpagetoc |
Section | |||||||||||||||
UI Path
||Render Settings window|| > Render Elements tab > Render ID
Attributes
Section |
The parameters for this render element appear in the Attribute Editor under Extra V-Ray Attributes. |
Common Uses
A common usage of this is to use the colors produced in the Render ID render element to create a mask or alpha channel in post production that covers everything with that Color. Another use is when you have a scene with many similar looking parts with similar shading and have the Render ID above this, desaturated of all color and set to an Overlay mode with a low opacity to add variation. A variation on this is to use the resulting desaturated Render ID render element as a luminance mask to then control color correction, etc.
