Square Enix © Goodbye Kansas
This page provides information on the Object ID Render Element which isolates individual objects with different colors based on IDs for compositing purposes.
In Maya, Object IDs can be added as an Extra V-Ray Attribute. Two or more objects in the scene can share the same Object ID.
The Object ID Render Element creates selection masks based on Object ID that shows each object (by Object ID) in a solid unshaded color.
Attributes
Enabled – When enabled, the render element appears in the V-Ray frame buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.objectID.vrimg).
Common Uses
The Object ID Render Element is useful for isolating geometry in a scene based on the Object ID. This means that items can be isolated by use of a matte created from the solid colors within the Object ID pass.
Matte created in composite by using only the red channel
Original beauty render
Glow and brightening added to the composite using matte created from
Object ID Render Element red channel (as a mask in composite)
Setup
  • Select the geometry that an Object ID Render Element is needed for.
  • Add the Object ID attribute Attributes > VRay > Object ID while the shape node is active for the geometry.
  • Set the Object ID to the required value. Note: each number corresponds to a different color.
  • Open Render Settings and go to the Render Elements tab and from the Available render elements add an Object ID render element.
The name of the Object ID render element must consist of the name of the Object ID itself, a dot and then any other string to be properly read in Nuke. For example, VRayObjectID.example . Do not include numbers in the name.
