||Select particles|| > Attribute Editor > Attributes menu > VRay > (select attribute set)
Per-Particle Attribute Export
Section | |||||||||||||||||||||||||
Sprite Orient
Point Size
Cache Interpolation
Instancer Overrides
This group is used with Instancer nodes, in order to pass per particle attributes that can override attributes of the instanced geometry.
