||Select transform node|| > Attribute Editor >  Attributes menu > VRay > (select attribute set)
Image Added
Skip Rendering
width62%
This group allows you to exclude parts of the scene from rendering.
width62%
Skip rendering – When enabled, the objects below the transform are not included in the V-Ray scene and are not be rendered.
Expand
titleScripting
UI Text Box
typeinfo
Enter this MEL code snippet to Add this V-Ray Extra Attribute to the named object (here called "pSphere1"):
vray addAttributesFromGroup "pSphere1" "vray_skip_export" 1;
Attribute name that is added with the above MEL snippet :
vraySkipExport
width5%
width33%
 Image Added
Image Removed
Object ID
width62%
This group allows to assign an object ID to parts of the scene, for use with the Multimatte render element.
width62%
Object ID – Specifies an ID for the objects below the transform.
Expand
titleScripting
UI Text Box
typeinfo
  vray addAttributesFromGroup "pSphere1" "vray_objectID" 1;
vrayObjectID
width5%
width33%
Image RemovedImage Added
User Attributes
width62%
Allows the user to specify their own attributes, which can then be accessed with the VRayUserColor  and VRayUserScalar textures to provide per-object values for shading attributes. They can also be used in the file name of File nodes to resolve the bitmap file name on a per-object basis. Several attributes can be specified in the string, separated with a semicolon ';' character. User attributes can also be specified on shape nodes. The final string of user attributes for a given object is a concatenation of the user attributes specified on the shape of the object and the user attributes specified on its parent nodes along the DAG path. This allows to conveniently add attributes to a large part of the DAG hierarchy.
width
62%
User attributes – A list of attributes separated by semicolons that are assigned to the mesh.
Expand
titleScripting
UI Text Box
typeinfo
  vray addAttributesFromGroup "pSphere1" "vray_user_attributes" 1;
vrayUserAttributes
width5%
width33%
