||Select Surface Luminance node|| > Attribute Editor > Attributes menu > VRay > Luminance options
Section | |||||||||||||||
Setup
The Luminance Options are most commonly used to generate an extra render element with masks for the lit and unlit points of objects in the scene. The common setup is to use the surfaceLuminance node as a texture connected to an ExtraTex render element.
