This page provides information on the Local ray server attribute set that can be added to meshes.
The attributes in this section can be added to any polygonal mesh object or to a VRayDisplacement node. The local ray server helps reduce memory usage for many instances of view-independent displacement and/or subdivision.
UI Expand
titleUI Path
: ||Select mesh|| > Attribute Editor > Attributes menu > VRay > Local ray server
Image Modified
Attributes
width62%
Local ray server – Enables an option in V-Ray that helps reduce the memory usage for scenes with many instances of objects with view-independent subdivision and displacement.
width5%
width33%
