width62%
The Multi Matte ID Render Element provides a mask for individual objects and/or materials, based on the Multi Matte IDs that have been added as Extra V-Ray Attributes.
The Multi Matte ID Render Element contains no shading information at all, and only contains blocks of color that correspond to each Multi Matte ID . It uses the Multi Matte ID set when the Material ID attribute is added to a material.
width5%
width33%
Image Added
Image Removed
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Multi Matte ID
width45%
Image Modified
width10%
width45%
Render (menu) > Render Settings > Multi Matte ID
Image Modified
width5%
width33%
Attributes
width62%
Enabled – When enabled, the render element appears in the V-Ray frame buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.multimatteID.vrimg).
UI Text Box
typenote
This render element is not supported with V-Ray GPU rendering.
width5%
width33%
