width62%
The Raw Reflection Filter Render Element is similar to the Reflection Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection.
width5%
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Raw Reflection Filter
width
33%
Image Removed
UI Path
45%
button||
Image Added
width10%
width45%
Render (menu) > Render Settings > Raw Reflection Filter
Image Added
width5%
width33%
Image Added
width62%
Enabled – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawReflectionFilter.vrimg).
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
UI Text Box
typenote
This render element is not supported with V-Ray GPU rendering.
width5%
width33%
