width62%
The Raw Reflection Filter Render Element is similar to the Reflection Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Raw Reflection Filter
width45%
width10%
width45%
Render (menu) > Render Settings > Raw Reflection Filter
width5%
width33%
