The Raw Reflection Filter Render Element is similar to the Reflection Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection.
UI Expand
title
UI Path: ||Display Render Settings button|| > Render Elements tab > Raw Reflection Filter
width
45%
||Display Render Settings button||> Render Elements tab > Raw Reflection Filter
width
10%
width
45%
Render (menu) > Render Settings > Raw Reflection Filter
To use render elements, select from the Available render elements column and click the Add button to add the passes you wish to generate at render time. When you render the scene, the added render elements listed in the column on the right, will also render, which can be viewed from the VFB window's channel drop-down menu.
For more information on the parameters on this dialog, see the Render Elements tab page.
