Enabled – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawReflectionFilter.vrimg).
UI Text Box
type
note
This render element is not supported with V-Ray GPU rendering.
width
5%
width
33%
Fancy Bullets
type
circle
The Raw Reflection Filter Render Element is useful when a precise mask is needed for reflective objects. Unlike the Reflection Filter Render Element, there is no need to clip or readjust values when pure black or white is required for the composite.
