width62%
The Self Illumination Render Element isolates self-illuminated materials, including V-Ray Mesh Lights, objects with the VRayLightMtl, and any objects with Self-Illumination enabled in their V-Ray material. This render element is useful for brightening or color-correcting self-illuminated materials in the final composite.
For example, the material VRayMtl has a parameter for self-illumination. If this parameter is set to a non-black color value, this render element will show the results of the self-illumination.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Refraction glossiness
width45%
Image Added
width10%
width45%
Render (menu) > Render Settings > Refraction glossiness
Image Added
width5%
width33%
