Anchor
OceanSubdiv
OceanSubdiv
Example: Ocean Subdivs
width10%15%
width40%70%
Before after
afterLabel8 subdivs
beforeLabel2 subdivs
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
width15%
Anchor
UnderwaterGoggles
UnderwaterGoggles
Example: Underwater Goggles
width15%
width70%
Before after
afterLabelOn
beforeLabelOff
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image Removed
Ocean subdiv. = 2
width40%
Image Removed
Ocean subdiv. = 8
width10%15%
Anchor
MeshSmooth
MeshSmooth
Prevent Self Intersection | mbself – In certain cases, the shifted all Mesh modes, some motion blurred vertices might penetrate the opposite side of the geometry. When enabled, this option prevents such situations. The self-intersection analysis is expensive, so enable this parameter only when an intersection is obvious.
