This page provides information on the Local ray server attribute set that can be added to meshes.
width62%
The attributes in this section can be added to any polygonal mesh object or to
VRayDisplacement node. The local ray server helps reduce memory usage for many instances of view-independent displacement and/or subdivision.
title
UI Expand
UI Path: ||Select mesh|| > Attribute Editor > Attributes menu > VRay > Local ray server
width5%
Image Removed
width33%
Image Added
Attributes
width62%
Local ray server – Enables an option in V-Ray that helps reduce the memory usage for scenes with many instances of objects with view-independent subdivision and displacement.
width5%
width33%
