width62%
The attributes in this section can be added to any polygonal mesh object or to a VRayDisplacement node. The local ray server helps reduce memory usage for many instances of view-independent displacement and/or subdivision.
UI Path: ||Select mesh|| > Attribute Editor > Attributes menu > VRay > Local ray server
width5%
width33%
