width62%
The V-Ray Additional Attributes can be added to particles. Adding these attributes will add new settings in the Extra VRay Attributes rollout.
UI Path: ||Select particles|| > Attribute Editor Attributes menu > VRay > (select attribute set)
width5%
width33%
