V-Ray GPU offers 4 different tabs in the Render Setup window.
circle
width20%
UI Text Box
sizemedium
Fancy Bullets
type
V-Ray tab
Global Illumination settings, Frame Buffer and Environment settings. Find out more: V-Ray tab
width5%
width20%
UI Text Box
sizemedium
GPU Performance Tab
Distributed Rendering options, selection of rendering devices, tweaking Texture rendering and Utilization. Find out more: GPU Performance Tab
width5%
width20%
UI Text Box
sizemedium
Settings tab
Various settings including Global Switches and Image Sampler. Find out more: Settings tab
width5%
width20%
UI Text Box
sizemedium
Render Elements
Creation and control of render elements for beauty pass compositing and post-production. Find out more: Render Elements
width5%
