The Perf. tab of the Render Setup window contains all performance related settings for V-Ray GPU. You can control the Utilization and Textures settings, or choose which devices to be included in the rendering and also set up Distributed Rendering.
UI Expand
titleUI Path
: ||Render Setup window|| > Performance tab > Textures rollout
 Performance tab (Renderer set to V-Ray GPU)
Image Added
Rollouts
The Performance tab consists of four rollouts:
circle
width20%
UI Text Box
sizemedium
Fancy Bullets
type
Utilization rollout
Adjust parameters concerning shooted rays during rendering (both production and IPR rendering). Find out more: Utilization rollout
width5%
width20%
UI Text Box
sizemedium
Textures rollout
Controls size and resolution of textures with V-Ray GPU rendering. Find out more: Textures rollout
width5%
width20%
UI Text Box
sizemedium
Distributed Rendering rollout
Set Distributed Rendering settings. Find out more: Distributed Rendering rollout
width5%
width20%
UI Text Box
sizemedium
V-Ray GPU Render Devices Select
Easy access toa list of devices to include/ exclude from the rendering process. Find out more: V-Ray GPU Render Devices Select
width5%
