The Refraction Render Element stores refraction information calculated from materials--such as glass or water--that refract objects behind them in the camera's view. This means the brightness, coloration, etc. of the refractions can be adjusted without the need to rerender.
Any material in a scene that has a value set for its Refraction parameter will generate refraction information that can be seen in this render element. A surface with no refraction values set in its material(s) will contain no information in the render element and therefore render black.
The Refraction Render Element is a key component in the mainBeauty Elementand can easily be used to control the refractions in the Beauty composite.
The Refraction Render Element itself is already a composite of theVRayRawRefractionrender element multiplied by theVRayRefractionFilterrender element. When finer control over refractions is needed in the composite, add these additional two channels to the output along with the VRayRefraction render element channel.
width
5%
width
35%
Image Removed
section
UI Expand
title
UI Path: ||Render Setup window|| > Render Elements tab...
||Render Setup window||> Render Elements tab > Addbutton >VRayRefraction
Image Added
width
20%
5%
width
60%
35%
Image Modified
width
20%
width
60%
VrayVFB– When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Color mapping – Applies – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Setup window to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies – Specifies whether to denoise this render element.
