width60%
VRScansZone is used with specific vrscan materials which consist of two or more clearly defined sub-materials (e.g. some fabrics with pattern). It renders a mask for the zone which is shaded with the respective sub-material. The result mask is monochrome with white area corresponding to the distribution of the specified sub-material and black color fill for all the other parts of the image.
The VRScansZone render element only works with the scanned materials which have the respective zones channels defined inside them.
width5%
width35%
Image Removed
UI Expand
titleUI Path: ||Render Setup window|| > Render Elements tab...
||Render Setup window||  > Render Elements  tab  > Add  button  > VRScansZone
Image Added
20%
width
5%
60%20%
width
35%
Image Modified
width
width60%
VrayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Color mappingApplies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Setup window to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise –  Specifies whether to denoise this render element.
Zone – Determines the zone that is pained white.
width5%
width35%
