width60%
VRScansPMaskElement render element allows color changes to a V-Ray Scanned Material in post-compositing. It provides a mask for the V-Ray Scanned material that can be used to change its color.
width5%
width35%
Image Removed
section
UI Expand
titleUI Path: ||Render Setup window|| > Render Elements tab...
||Render Setup window||  > Render Elements  tab  > Add  button  > VRScansPMaskElement
Image Added
35%
width
5%
30%35%
width
35%
Image Modified
width
width60%
VrayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Color mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Setup window to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise –  Specifies whether to denoise this render element.
width5%
width35%
