width62%
The Coverage Render Element holds anti-aliasing data based on the Render ID Render Element. When the Coverage Render Element is multiplied by the Render ID Render Element in compositing, it adds anti-aliasing to the Render ID channel, providing a quick object mask.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Coverage
Image RemovedImage Added
width5%
width33%
