width62%
The Subsurface Scattering Render Element stores subsurface information from VRaySSS2 materials as an image. This render element can then be used to enhance or color-correct just the subsurface scattering component of the image during the compositing process.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > SSS
Image RemovedImage Added
width5%
width33%
