The Multi Matte ID Render Element isolates objects with specific Multi Matte IDs for compositing purposes.
width62%
The Multi Matte ID Render Element provides a mask for individual objects and/or materials, based on the Multi Matte IDs that have been added as Extra V-Ray Attributes.
The Multi Matte ID Render Element contains no shading information at all, and only contains blocks of color that correspond to each Multi Matte ID . It uses the Multi Matte ID set when the Material ID attribute is added to a material.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Multi Matte ID
width5%
width33%
Attributes
width62%
Enabled – When enabled, the render element appears in the V-Ray frame buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.multimatteID.vrimg).
UI Text Box
typenote
This render element is not supported with V-Ray GPU rendering.
width5%
width33%
Multimatte ID Render Element Set up Procedure
Here's the workflow for setting up and using the Multi Matte ID Render Element:
Select the material in the Hypershade that a Multi Matte ID Render Element is needed for.
width62%
 Add the Material ID attribute Attributes > VRay > Material ID.
width5%
width33%
width62%
 Set the Multi Matte ID to the required value. Note: each number corresponds to a different color.
width5%
width33%
width62%
 Open Render Settings and go to the Render Elements tab and from the Available render elements add a Multi Matte ID render element.
width5%
width33%
Common Uses
A typical usage of this render element, is to use the colors produced in the Multi Matte ID to produce a mask or alpha channel in post production that covers everything with that Multi Matte ID.
width10%
width40%
The Beauty Render Element
width40%
width10%
width10%
width40%
The Alpha Matte produced from the red channel of the Multi Matte ID render element
width40%
Reflection Render Element prior to grading using a matte created from the red channel of the Multi Matte ID Render Element
width10%
width10%
width40%
The Reflection Render Element using a matte created from the red channel of the Multi Matte ID Render Element to add contrast to the reflection on the suit and tint it blue
width40%
The resulting composite using the Multi Matte ID's
for Control changing material colors without re-rendering
width10%
