The Multi Matte ID Render Element isolates objects with specific Multi Matte IDs for compositing purposes.
Here's the workflow for setting up and using the Multi Matte ID Render Element:
Select the material in the Hypershade that a Multi Matte ID Render Element is needed for.
A typical usage of this render element, is to use the colors produced in the Multi Matte ID to produce a mask or alpha channel in post production that covers everything with that Multi Matte ID.
