This page provides information on the Raw Sheen Filter Render Element.
width62%
The Raw Sheen Reflection
Filter Render Element is similar to the Sheer Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Raw Sheen Filter
Image Modified
width5%
width33%
 Image Added
Attributes
width60%
Enabled When enabled, the render element appears in VFB.
Deep output – Specifies whether to include this render element in deep images.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.raw_sheen_reflection.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
width5%
width35%
