with the main difference being that all Sheen render elements can be subtracted from the main back-to-beauty composite, graded, and added back in.
The Sheen Reflection Render Element stores reflection information calculated from the materials' reflection values in the scene. Surfaces with no reflection values set in their materials will contain no information in the render pass and will therefore render as black.
The Sheen Reflection Render Element is formed by multiplying the Raw Sheen Reflection Render Element by the Sheen Filter Render Element . So while the raw sheen reflection pass gives the full reflection of objects reflecting in the scene, the sheen reflection filter sets how much of that reflection should come through in the composite. The two are multiplied together to create the Sheen Reflection pass which gives a true representation of the reflection in the scene.
To use render elements, select from the Available render elements column and click the Add button to add the passes you wish to generate at render time. When you render the scene, the added render elements listed in the column on the right, will also render, which can be viewed from the VFB window's channel drop-down menu.
For more information on the parameters on this dialog, see the Render Elements tab page.
width
5%
width
33%
Image Added
Attributes
width
60%
Enabled – When enabled, the render element appears in VFB.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.SheenReflection.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
