This page provides information about the Performance Tab of the Render Setup window of V-Ray GPU.
> Performance tab > Textures rollout
title
width60%
The Perf. tab of the Render Setup window contains all performance related settings for V-Ray GPU. You can control the Utilization and Textures settings, or choose which devices to be included in the rendering and also set up Distributed Rendering.
UI Expand
UI Path: ||Render Setup window||
 > Performance tab (Renderer set to V-Ray GPU)
width5%
width35%
Image Modified
Rollouts
The Performance tab consists of four rollouts:
