First, we make the material translucent, then we show you how to introduce color tint. Later, we adjust the specular component of the material and finish the plastic look by adjusting a few key options.
Prerequisites
For the purpose of the tutorial, we focus only on the shampoo bottle material.
The bottle cap uses a VRayFastSSS2 VRayFastSSS2 material with the color mode set to Sub-surface color and scatter radius and the single scatter set to Raytraced (solid).
For the final image, we use a VRayBlendMtl to add the bottle labels. The plastic bottle material shown in the tutorial is used as the Base Material, and two Coat Materials are used - one for the golden label and one for the overall front label.
UI Text Box | ||
Scale Unit scale is crucial for the accuracy of the VRayFastSSS2 material. In this scene, we work in centimeters. The scatter radius and scale parameters are observed to be correctly set according to the dimensions of the bottle geometry. |
Make it Translucent
Section | |||||||||||||||
Color the Bottle
Specular Layer and Phase Function
Final Touch
