Date – July 7, 2014
Download – No longer available
New Features
Render Settings
Fancy Bullets
typecircle
  • "Render mask" option to (re)render only a subset of the scene nodes
Modified Features
Fancy Bullets
typecircle
  • Optimized rendering performance with tiled textures
  • Optimized primary visibility with maya hair and vray proxies
  • Reduced the memory usage for hair and particles
  • An IOR parameter for the VRayEnvironmentFog shader
  • Help messages for the vrend MEL command
  • Remove the pre-render export (and the MAYA_DISABLE_BATCH_RUNUP env variable) when using the "Use camera path" GI option
  • Disable clamping of velocity render element by default
  • Option to manually clear the geometry and bitmap cache
  • Ability to use OS native browser when Importing V-Ray proxy
  • Automatically connect a placeEnvTex to a file node for a material environment override
VRayMtl
Fancy Bullets
typecircle
  • the default cuttoff threshold is now 0.001 instead of 0.01 for new materials
VRayFastSSS2/ VRaySkinMtl
Fancy Bullets
typecircle
  • Optimized raytraced multiple scattering
V-RayMesh
Fancy Bullets
typecircle
  • Support for alembic hair uvs
VRayLightMtl
Fancy Bullets
typecircle
  • Option to multiply the intensity by the opacity
Render Settings
Fancy Bullets
typecircle
  • The "Clear render view" option should be renamed to "Clear frame buffers" and work also with the VFB
Sampler Info
Fancy Bullets
typecircle
  • New extra V-Ray attribute to specify which UV set should be returned from the uv output
ply2vrmesh
Fancy Bullets
typecircle
  • Swaps vertex-color-channel-names during the conversion
  • Doesn't transfer vertex colors with houdini mesh
  • Print the number of (preview) hair/particles with the "-info" option
vrimg2exr
Fancy Bullets
typecircle
  • Print information about the rendered region in the image with the "-info" option
Bug Fixes
Fancy Bullets
typecircle
  • NURBS surfaces do not generate velocity information
  • Shutter efficiency uses wrong formula
  • The progressive sampler doesn't update properly the Maya's progress bar
  • Light mesh crashes with animated alembic meshes when the topology changes
  • The Maya render view updates slower than the VFB
  • Disabling cached geometry leads to crashes on Linux
  • Invisible lights show up with global volumetrics
  • Different naming convention for multichannel EXR
  • Folders are created when vray is set not to save images
  • TexRemap animated color position outputs wrong value
  • Incorect velocity render element when converting to a Polygon Dynamic Mesh
  • Crash with velocity render element and Maya hair, when motion blur is off
V-Ray RT
Fancy Bullets
typecircle
  • Renderable curves param changes are not detected
  • Changing the shader of VTayMtlOSL while RT is running crashes Maya
  • Changing the Color Space parameters of OCIO texture is not detected
  • Using -rtsamplelevel with the command line leads to very slow calculations
  • Crash with 2d pan and zoom
VFB
Fancy Bullets
typecircle
  • Maya crashes when an image is being deleted/removed from the render history
VRayMesh
Fancy Bullets
typecircle
  • Alembic particles and hair imported as proxies don't render with VRayMtl
  • .vrmesh files with hairs do not quite respect the dynamic memory limit
  • Crash during the export, if the mesh has color set selected for velocity
  • Clipped particles when motion blur is on
VRaySwitchTransform
Fancy Bullets
typecircle
  • Fatal error building the scene if connected shape-node is deleted/removed
VRMatMtl
Fancy Bullets
typecircle
  • The ASGVIS V-Ray plugins are missing from the OSX installation causing inability to render ASGVIS vismats
Maya fluids
Fancy Bullets
typecircle
  • Locity render element and Maya hair, when motion blur is off
  • Rendering issues with adaptive grid and motion blur
  • The Shadow Opacity was not working like with Mental Ray
XGen
Fancy Bullets
typecircle
  • When doing a maya batch render (from the UI) no instanced XGen geometry is rendered
