changes.mady.by.user Unknown User (zheni.metodieva)
Saved on May 27, 2020
Saved on Jul 30, 2020
||Right-click on the geometry|| > Assign New Material... > VRay section > VRay Flakes Mtl
Image Added
||V-Ray Shelf|| > Right-click to Create V-Ray Materials button > VRay Flakes Mtl
||Hypershade|| > Window tab > Create... > VRay section > VRay Flakes Mtl
Image RemovedImage Added
These options are inactive with V-Ray GPU engine.
Cutoff threshold – – Cutoff threshold for the reflections of the different layers. This parameter is not available when the renderer is set to CUDA.
Double sided – When enabled, the material is double-sided.
Trace reflections – Global switch to toggle reflections for all layers.
Max depth – The number of times a ray can be reflected.
