width57%
VRayC4DBake is a utility texture that helps you render native Cinema 4D textures with V-Ray with greater quality.
V-Ray does not support native natively Cinema 4D textures , but VRayC4DBake can bake a native texture to a bitmapand sometimes they might lack the needed detail.
For greater control over the quality, use the VRayC4DBake texture.
width5%
width38%
