This page introduces the settings found in the Sampler tab of the V-Ray Renderer parameters.
Section | ||||
Section | |||||
Image Sampler
The Image Sampler panel controls overall image sampling. Raytrace renders, like V-Ray, shoot rays out from the camera to sample what is found in the scene to help determine what color each pixel will be in a rendered image. The settings used to adjust how V-Ray does this, and the relationship between pixels in the render, can be found on the Image Sampler (Anti-Aliasing) page.
Render Region Division
The parameters in this panel adjust V-Ray's rendering regions (sometimes referred to as buckets), when the Image Sampler Type is set to Bucket. A bucket is a rectangular (usually square) section of the currently rendered frame that is rendered independently from other sections. Buckets are used when V-Ray uses a non-progressive image sampler. For more information please see the Render Region Division page.
