The Color Channel is a container node that allows the output of almost every render channel available in V-Ray. It allows you to extract different color components from the image (i.e. Diffuse, Reflections, Refractions, etc.) to use later for tasks like compositing.
UI Path
Column | ||
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > V-Ray Color Channel
(RE)
width | 45% |
||mat Network|| > V-Ray > Render Channel > V-Ray Color Channel
Column | ||
(RE)
Section | |||||||||||||||
Anchor | ||||
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
