The Extra Texture Render Element shows the rendered image with a single texture applied to all objects in the scene. The texture applied to the scene can be a bitmap or a procedural texture such as as VRayDirt or VRayCurvature .
Note: Specific objects can be excluded from this Render Element by disabling the Generate Render Elements option in the VRayObjectProperties node for the selected object(s).
UI Path
: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel >
V-Ray ExtraTex (RE)
Section | |||||||||||||||
