The Portal Light option in V-Ray Rectangle light is now considered a legacy option and is no longer exposed in the UI. Rectangle lights in files saved with previous V-Ray versions and this option enabled will still display have it available. Regardless, for best performance consider disabling it and using the Adaptive Dome Light option instead.
