width57%
The V-Ray AL Surface shader is V-Ray's implementation of Anders Langland's alShader, which is designed to reproduce the appearance of skin. The current version takes into account diffuse reflection, two levels of reflection, and subsurface scattering.
UI Path: ||V-Ray|| > AL Surface Material
||Create|| > V-Ray > AL Surface Material (disabled Separate for V-Ray materials)
width5%
width38%
Image Modified
Diffuse and Opacity
